Home › Forums › Products › Stompboxes › H9: any way to create a “manual” or “fixed” phaser patch?
July 19, 2018 at 2:13 pm #114842
StSpider
ParticipantSo far I haven’t been able to do this except by using an expression pedal.
I want a patch where the phasing does not move, where the LFO is stuck in whatever place I set it with a potetiometer. Like in the electro harmonix bad stone, you have a “manual ” switch and you set the frequency with a dedicated pot.
Is there any way to do this with the H9 phaser?
Or any way to simulate the effect with a different algo (filter or wah or something)?
I want to do this without an expression pedal.
Thanks a lot
July 19, 2018 at 3:13 pm #149742StSpider wrote:
I want a patch where the phasing does not move, where the LFO is stuck in whatever place I set it with a potentiometer. Like in the electro harmonix bad stone, you have a "manual " switch and you set the frequency with a dedicated pot.
So you want to use the buttons and the black knob on your H9 to control the parameter? You can try to assign the SPEED parameter to the XYZ buttons (anyone) on the H9. Then you should be able to do what you want by press the X (or Y, Z) button and turn the encoder to change the value.
July 20, 2018 at 9:58 am #149755
StSpider
Participantbohan wrote:StSpider wrote:I want a patch where the phasing does not move, where the LFO is stuck in whatever place I set it with a potentiometer. Like in the electro harmonix bad stone, you have a “manual ” switch and you set the frequency with a dedicated pot.
Thanks, I’ll try that!
July 20, 2018 at 10:22 am #149756
bansta
ParticipantHe would like to have a posibility to set the SPEED = 0.
I would like to have the same feature in the Flanger.
July 20, 2018 at 2:04 pm #149760
ParticipantStSpider wrote:… Or any way to simulate the effect with a different algo (filter or wah or something)?I want to do this without an expression pedal …
bansta wrote:… I would like to have the same feature in the Flanger …That could be simulated with other algorithms, but I would try the Flanger first. Dialing DEPTH down to 0 will disable the sweep / SPEED. Set the INTENSITY (feedback / regeneration) to maximum, and then back it off slowly, until you’re hearing the desired effect.
For Phaser-type FX, INTENSITY would be very low, and a POSITIVE / NEGATIVE TYPE would be more subtle. I have the MDO O/P parameter here mapped to the expression pedal, but you can dial it in manually. The same parameter can be found in the Chorus ORGANIC TYPE.
As an aside, the current expression pedal / ribbon position is saved within a preset, so those features can be used for initial adjustments. More information here:
