H9 aux switch + expression pedal
Home Forums Products Stompboxes H9 aux switch + expression pedal
    • #111377
      rdnzl
      Hello there
      Can somebody tell me hiw to acheive this? Apparently with a Y cable and some tweaking, it's doable…
      Cheers
    • #125380
      There are some software problems making this difficult. Apologies. These are fixed in the next release, due in a month or two.
      You will need an "insert type" Y-cable, with a stereo jack going to two mono jacks. The tip of the stereo needs to go to the pedal, while the ring goes to the switch. Example from Amazon:
      Hosa Cable STP203 TRS To Dual 1/4 Inch Insert Cable – 9.75 Foot  ($1.99)
    • #125487
      Lars Blomstrand
      So there is a bug there. I thought I did something wrong with my soldering/programming… The aux switch only worked when the exp. was in the over half of the travel. Interesting result…? NOT!
      I have a wish for the aux switch. I know that the switch itself must be of a "momentan" typ but I wonder if there would be a chans to be able to select the result of the aux switch pressing to be selectable "Momentan" or "Latching". In live situation i often only want to engage the H9 on short passes in the song and don't want/have time to press the aux switch twice. It's also a better feel toghether with speed up/down of the moulation efx. To me anyway.
