Home › Forums › Products › Stompboxes › H9 + Barn3 Ox9 + Mission SP-H9
June 5, 2020 at 10:41 pm #115946brewjoParticipant
I’m pretty new to the world of pedals and feel like I jumped off the deep end. Hoping someone can help me. I have a Eventide H9 Max. Just my luck I had listed a Barn3 OX9 and a Mission Engineering SP-H9 expression pedal on a wish list. I ended up getting both but I cannot figure out how to make them all work together.
What I would like to do is have the Barn3 Left switch to cycle up through the presents and the right side to cycle down. And I would like the Expression pedal to increase or decrease the amount of the effect loaded; i.e. more or less Fuzz.
Is this possible? If so, can someone explain how to need to map this out with the app?
June 6, 2020 at 3:57 am #155017
I don't think this is going to work out. See this manual (https://static1.squarespace.com/static/539f0880e4b0e0318ea3192f/t/5940029fb8a79bde2d979ab5/1497367242457/OX9-Manual-2017.pdf).
It says "When using an expression pedal, the H9 only allows you to have one additional auxiliary footswitch (the left one)"
June 6, 2020 at 4:39 pm #155020camnParticipant
yeah you need MIDI to accomlish all of that at the same time
June 7, 2020 at 3:52 am #155026camnParticipant
Though for real… For cheaper than a Barn3 anyone could build a midi controller that could do everything you ever wanted.
Fight the patriarchy
June 6, 2020 at 4:21 pm #155019brewjoParticipantbohan wrote:
I don’t think this is going to work out. See this manual (https://static1.squarespace.com/static/539f0880e4b0e0318ea3192f/t/5940029fb8a79bde2d979ab5/1497367242457/OX9-Manual-2017.pdf).
It says “When using an expression pedal, the H9 only allows you to have one additional auxiliary footswitch (the left one)”
I was suspecting this but hoping I missed some secret that would let me do what I was after.
Currently on the H9 I can Cycle Up, on the Barn3 I can Cycle Down (Left). So I should be able to use the expression pedal to increase / decrease?
Yes. You can do this.
