Home › Forums › Products › Stompboxes › H9 Bluetooth doesn’t connect to MacBook
- This topic has 16 replies, 7 voices, and was last updated 4 months, 1 week ago by
olliebollie.
February 22, 2020 at 12:55 pm #115785
I’ve got three H9s. One of them connects to my MacBook, the other doesn’t connect, and I’ve never tried connecting the third to my MacBook. All three connect to my iPad with zero issues. Any ideas?
I’ve got a 2015 MBP running Mojave. My iPad is, I think, an Air 2 (purchased new in late 2014).
From what I remember Bluetooth was only supported for iOS and android unless somethings changed.
I have two MBP that I connect my H9 with no problem.
February 24, 2020 at 4:52 pm #154153
https://www.eventideaudio.com/community/forum/stompboxes/h9-will-not-connect-new-macbook-pro-sierra
Some users have suggested solutions to this issue. You may try them and see if it works out for you.
March 16, 2022 at 2:18 pm #162863
hi Bohan
I’m getting a 404 on the 2 links you gave for debugging pairing H9s on Bluetooth
If you cd repost them that’d be great
Thanks:L
March 16, 2022 at 2:26 pm #162864
hi Bohan
One of the H9s is not linking up
The display when I turn on Bluetooth (XYZ buttons) says
“BT E11”
Then it reverts to the Preset name
Any clues about BT E11?
Thanks
:L
ps: already reset the Bleutooth device, restarted the MBP etc. so I tried to ‘clean it all out’Attachments:
March 22, 2022 at 7:02 pm #162950
That sounds like a hardware issue. You should email support@eventide.com
March 22, 2022 at 7:07 pm #162951
Sorry. The old links won’t work because we updated our website. Here they are:
February 25, 2020 at 4:52 am #154159
I only have one H9 but it would not connect to my MBP until I turned off the bluetooth on my iphone which also has H9 Control installed. I’m sure I would achive the same result if I removed the H9 from my available devices list on my iphone, but it was just easier to turn bluetooth off.
February 25, 2020 at 10:54 am #154160
Apologies if this has already been tried/suggested…
I find that if you choose to manually connect using Bluetooth from H9 Control, higlhlight the pedal you want on the Bluetooth connection screen and then choose “Browse” rather than just double clikcing the H9, it’s more relaible. It can sometimes take a couple of goes but when it does connect it stays connected and you can repeat the process to have multiple H9’s up in H9 control.
January 7, 2022 at 4:01 pm #161494
I can not pair my h9 max with no device, which I could before, but, from nowhere, it stopped, I use original source and everything else.Not the Bluetooth light lights up, I already did everything they suggested, and some more users have the same problem
August 16, 2022 at 8:04 pm #165046
Same, windows app crashes. Also no bluetooth on pedal. It says bluetooth off and won’t flip. Now tech will cut in and tell me to hit the xyz buttons together which I’ve done to no effect. Had to take this out of my recording rig as it’s way to buggy and unreliable to be used for business.
August 22, 2022 at 7:38 pm #165107
Does the Bluetooth LED light up and down when you press the XYZ buttons simultaneously? If it’s lit, it means the Bluetooth is ON.
September 10, 2022 at 9:05 am #165510
i have five H9’s; usb is the least troublesome attachment method. bluetooth drops, doesn’t connect, has connection limitations, it’s really slow, etc… i use an mini4 ipad dedicated to h9 control.
September 16, 2022 at 1:31 pm #165611
I have tried the suggestions for getting my Mac (OS 12.5.7) to connect to my H9. H9 shows up on the Mac as an active Bluetooth device and it says it connects. However, the app controls do not work even when it says it is connected via Bluetooth. iOS on iPhone and iPad work fine. I compose using my Mac. Please advise.
September 19, 2022 at 9:54 am #165626
Do you connect to your H9 in H9 Control? Open H9 Control -> Manually Connect to a device -> Connect via Bluetooth -> Select your H9 and click Browse
December 9, 2024 at 8:01 am #186762
Don’t try to connect bluetooth first via system settings.
Instead just open the H9 desktop application: When “Device not found” window appears, choose “manually select a device”.
Then choose connect via Bluetooth; In the browse window select your H9-xxxxx device by clicking once on it, then click the browse button to select.
Done! The H9 desktop app now will connect via Bluetooth and stay connected.
