Home › Forums › Products › Stompboxes › H9 Bluetooth issues
- This topic has 10 replies, 6 voices, and was last updated 8 months, 4 weeks ago by
skywriter.
November 12, 2024 at 4:07 pm #186218
HELLO ,WHEN I AM APPAIRING MY PHONE WITH THE H9 ,THE LED BLUE IS THERE BUT IT NEVER FIX , ALWAYS FLASF THANKS
November 13, 2024 at 12:46 pm #186240
Please follow the troubleshooting instructions at the following link and let me know what happens.
https://s3.amazonaws.com/com.eventide.downloads/Product+Manuals/H9ControlManual.pdf
Below are a couple of things to make sure that you have tried.
- Verify that Bluetooth is enabled on your H9. A blue LED in the upper right-hand corner of the H9’s display will be lit up if Bluetooth is turned on. Turn Bluetooth off and on again on the H9 to reset the state of the Bluetooth chip by pressing the X, Y, and Z buttons on the H9 simultaneously.
- Make sure you are using the Eventide power supply.
- Make sure have tried one of the two factory resets below:
Restoring Factory System Settings
To restore System settings, power up the H9 while simultaneously pressing the Right Footswitch and the HOTKNOB button until [CLEAR] is displayed.
Restoring Factory Presets and System Settings
CAUTION: This function will overwrite any Presets that you have saved. To restore Factory Presets and all System settings, power up the H9 while simultaneously pressing the Right Footswitch and the big Knob until [INITIA] is displayed.
Make sure you have completely powered off your device (iOS or computer) and then powered it back on again.
If using a mobile device, reset the network settings. -
January 20, 2025 at 10:55 am #187828
What would really be helpful,,, hear me out on this,,, is to FIX THE ISSUE! Not everyone wants to try “reset it to factory”… and lose all presets we’ve worked to put in place. I have never had so many issues with a pedal’s connectivity. You’d think for what these things cost, a simple Bluetooth connection would not be an insurmountable issue. See picture for error notification (my bluetooth shows it as connected, after entering PIN) What does this even mean?
April 14, 2025 at 6:06 am #189552
Tengo el mismo problema. Amo el pedal pero es realmente frustrante. Todos los días lo intenté porque alguna vez conectó…:((
April 14, 2025 at 6:06 am #189553
April 14, 2025 at 6:07 am #189554
Aclaración: en mi caso, el teléfono conecta, es el ordenador el que no lo hace
June 3, 2025 at 11:10 am #190467
No hay ninguna ayuda? any help?
August 7, 2025 at 7:50 pm #191437
My widows 10 desktop will not detect the H9 – blue led lit. Any suggestions? BTW I tried turning it on while holding the right footsw and the hotknob – and it just says “INITI..”
September 30, 2025 at 9:34 pm #192343
I just bought an H9. The Bluetooth connection is totally unreliable. I am going to try a direct connection and if that doesn’t work I’ll sell the thing.
September 30, 2025 at 10:29 pm #192344
I got it to work with Windows 10. Used a 12 ft USB extension cord and it worked.
October 3, 2025 at 6:12 pm #192415
fwiw, i use an old ipad mini5 to connect FIVE H9’s in my setup with Bluetooth. sometimes one will drop out like PBark’s PNG immediately after connect in the morning, but reconnecting often solves the problem the very first time. after that they all stay connected all day (16 hours every day – unless i’m on vacation) without issue.
i often start playing right after i feed my ferrets, and it all works wonderfully.
