H9 Bluetooth with MacBook Pro “Not Connected”
Home Forums Products Stompboxes H9 Bluetooth with MacBook Pro “Not Connected”
Viewing 6 reply threads
    • #111798
      JNPMusic
      I'm having a problem getting the H9 to connect with my MacBook Pro. It will pair the H9 but after that it won't connect. My iPhone works great but for some reason I can't get the H9 to connect with the computer. Any suggestions?
      Thank you,
      John
    • #126360
      Dalmanours
      I guess You've tried to connect via blutooth. For this time it's impossible to do that. You can only connect your device via USB.
    • #126362
      JNPMusic
      Thanks! I found out it only works through USB…..Bluetooth would be a nice feature and then I wouldn't have to take it off my board every time I want to use it on the desk top.
    • #126370
      Currently Bluetooth only works with IOS and Windows. OSX does not use the IOS interface (don't ask me why), so it's a whole new piece of work. Maybe later
    • #126435
      gkellum
      Dalmanours:
      There's a new version of H9 Control out that has support for Bluetooth on Mac OS X and Windows.  You can now connect to your H9 over Bluetooth on your Mac by going to the Devices menu in the Mac menu bar and selecting "Connect via Bluetooth".
      http://www.eventide.com/AudioDivision/Support/Stompboxes/H9.aspx
    • #144944
      joegrant413
      I’ve tried many times, no luck. The H9 bluetooth works fine on my iPad and iPhone. Not the MacBook Pro running El Capiton 10.11.6.
      Just now I had the H9 literally sitting next to the Macbook. Also tried turning off the Wifi.
      The closest it gets is to say the passcode didn’t match. I enter it, but it makes no difference.
      Any tips?
      Thx,
      – Joe
    • #144948
      joegrant413
      Neve rmind! Well, I do suggest you folks recommend people download the latest version.
      Just now, I tried again. Didn’t work. Then I checked my software version (which, BTW, should be accessible from the Mac menu bar…)  It was 2.7.5, and your download page showed that 2.7.8 is the latest.
      So I trashed the old software, and loaded the new software. Connect fine now.
      Best wishes,
      – Joe
