Home › Forums › Products › Stompboxes › H9: Can I use MIDI for program changes and exp, and still use an aux switch for hotswitch?
May 19, 2020 at 4:17 pm #115919
chrism27
ParticipantHopefully my subject line explained it well enough. I am using a Disaster Area DPC-5 Gen 3 for program changes, bypass, and expression but it doesn’t have the ability to sent a CC for the hotswitch (at least not to my knowledge). I’d like to plug an aux switch into the exp jack and use that for the hotswitch (or another aux function). Does this work or is there an issue combining MIDI contol with aux switches?
May 19, 2020 at 7:56 pm #154910
camn
ParticipantNo issues I have that exact setup.
And I protested to Disaster back in the day that they could do better with the HotSwitch.
May 19, 2020 at 8:35 pm #154913
chrism27
ParticipantThanks!
May 19, 2020 at 10:23 pm #154919chrism27 wrote:
I am using a Disaster Area DPC-5 Gen 3 for program changes, bypass, and expression but it doesn't have the ability to sent a CC for the hotswitch (at least not to my knowledge).
You can use MIDI CC to control the hotswitch. It's call "Performance Switch (middle footswitch)" in the MIDI CC mapping menu in H9 Control.
May 19, 2020 at 11:55 pm #154922
camn
ParticipantLast I checked the Gen3 supported the hotswitch, but there were some timing issues. There was a tiny delay, which ruined it for me.
But I retired that pedal a while back, and they had some brisk updates, so maybe it is fine now?
Here was the discussion:
May 20, 2020 at 12:06 am #154924
chrism27
ParticipantUnfortunately the DPC-5 doesn’t allow for custom cc messages as far as I know.
Would I need to use a TRS cable for a single button aux switch, or is TS fine? -
May 20, 2020 at 12:35 am #154926chrism27 wrote:Unfortunately the DPC-5 doesn't allow for custom cc messages as far as I know. Would I need to use a TRS cable for a single button aux switch, or is TS fine?
Well, H9 can take any MIDI CC messages and map them to whatever functions you like.
If you want to use a single button aux switch, I believe both TRS and TS can work. TS should be fine.
