H9: change I change default settings for each algorithm?
Home Forums Products Stompboxes H9: change I change default settings for each algorithm?
    • #112748
      BarneyBrown
      Hi there,
      When I select a new algorithm on my H9, each algorithm has a default setting it uses – so for example, each time I open the Blackhole algorithm the 9 or so paramaters will always default to the same setting.
      Is there a way to change the default settings for each algorithm?
      Thanks,
      Daniel
    • #140021
      Sorry – the default settings are hidden hard coded presets, which can't be changed.
      But, if you were to create your own default presets, and load these as a starting point, it would come down to the same thing.
    • #140024
      BarneyBrown
      Great – thanks for the reply.
