Home › Forums › Products › Stompboxes › H9 Control background process on ipad
May 3, 2018 at 10:01 pm #114724
Stax_911
ParticipantHello,
I am using my H9 Control on an ipad pro.
I am driving several audio app simultaneity on the ipad (Aum, Audiobus, Loopy HD…) and each time I am opening an other app and come back, H9 Control has to re start.
I’d like to know if there is a way to make H9 control work in background process with other app, in order not to re-start when I come back. Is it clear ?
Thank you for your help.
May 3, 2018 at 10:07 pm #149142
gkellum
ParticipantStax_911 wrote:I'd like to know if there is a way to make H9 control work in background process with other app, in order not to re-start when I come back. Is it clear ?
No, there's no way to allow H9 Control to run in the background. We modified H9 Control to work like that when iOS 11 was released but it made it impossible for many users to connect to multiple H9 devices. Unfortunately, if an app uses Bluetooth, it won't function correctly if you let it run in the background.
Here's a link to the thread describing the problems people ran into when we tried to add support for running in the background.
https://www.eventideaudio.com/community/forum/stompboxes/help-communication-error
May 4, 2018 at 5:47 am #149148
mustafaicil
ParticipantThis should still be an option for people who are using only one H9. Not being able to switch back and forth is a major showstopper.
May 4, 2018 at 12:05 pm #149153
gkellum
Participantmustafaicil wrote:This should still be an option for people who are using only one H9. Not being able to switch back and forth is a major showstopper.
Well, unfortunately, this is not something that you can control from software. There's a settings file that gets submitted with the app that says whether the app supports background mode or not, and you can't override that setting from software. So, there's no mechanism for us to allow some users to opt into this and others not to.
May 4, 2018 at 12:42 pm #149154
mustafaicil
Participantgkellum wrote:mustafaicil wrote:This should still be an option for people who are using only one H9. Not being able to switch back and forth is a major showstopper.
Well, unfortunately, this is not something that you can control from software. There’s a settings file that gets submitted with the app that says whether the app supports background mode or not, and you can’t override that setting from software. So, there’s no mechanism for us to allow some users to opt into this and others not to.
Then a recommendation would be to have two versions of the software (one to manage a single device with background support; and another to support multiple devices). You will know this better but I assume most of your users have a single H9.
May 5, 2018 at 2:22 pm #149162
Stax_911
Participant[/quote]
[/quote]
Yes I totaly aggry. I am using only one H9 and that would be a good solution to allow users to choice for a multiple or single devices version of the H9 Control.
Thank you for your answer.
