Every time I try to load the presets from my H9 in the “Presets List” view I get a “Communication error!” message. See the attached image.
If I set the CLOCK OUT value to OFF within the H9 unit, then H9 Control loads perfectly fine.
Another strange behavior I notice when the CLOCK OUT value is set to ON is that it takes at least 10x more time to load the H9 Control (when the “Device connected!” popup message appears).
Another specifications:
Windows 7 64bit
H9 5.2.0[1]
