H9 control closes when saving preset to the pedal
Home Forums Products Stompboxes H9 control closes when saving preset to the pedal
    • #115712
      mbensou
        I have an issue with h9 control when saving preset through the app. It closes each time I try to save a preset to the pedal. (same when I try to enter the program changes receive map)
        My setup : 2 H9 connected through USB
        1 is working when I m saving to the pedal from H9 control.
        the other one is not and H9 control closes when I try to save or I try to load program changes receive map.
        Any help plz ?
        Thanks a lot.
      • #153781
          Please help us to help you.
          • What OS and version are you using ?
          • What version of H9control are you using ? (Try the latest if you are not using it).
          • When you say "H9 control closes" what exactly do you mean ? Please describe in detail what you see.
        • #153896
          mbensou
            Fixed thanks. Downloaded last version of H9 control
