H9 control feature request
Home Forums Products Stompboxes H9 control feature request
Viewing 8 reply threads
    • #113677
      terich
      I’d like to see the names of presets, not just the number, in the dropdown menu when choosing the “Save to H9” from the H9 Control ipad App. Right now it just shows a list of numbers to scroll through. If I could see the preset name in addition I could prevent myself from overwriting presets i need.
    • #144271
      gkellum
      terich wrote:
      I'd like to see the names of presets, not just the number, in the dropdown menu when choosing the "Save to H9" from the H9 Control ipad App. Right now it just shows a list of numbers to scroll through. If I could see the preset name in addition I could prevent myself from overwriting presets i need.
      That's a good idea.  We'll see if we can't get to that relatively soon.
    • #144272
      terich
      Awesome!
    • #144274
      Marcel
      Another request 🙂
      Sometimes when I name something in H9 Control for iPad I can’t see what I am writing: the iPad typewriter takes away my vision of the field in which I am writing. But this is not always the case, a bit weird, I can’t remember in what situation exactly I can’t see what I write. Nevertheless: the field in which you write letters should better be always above (and not under) the typewriter screen, so that you always can see what you write. To be honest: it is a bit annoying.
      • #144276
        gkellum
        Marcel wrote:
        Sometimes when I name something in H9 Control for iPad I can't see what I am writing: the iPad typewriter takes away my vision of the field in which I am writing. But this is not always the case, a bit weird, I can't remember in what situation exactly I can't see what I write. Nevertheless: the field in which you write letters should better be always above (and not under) the typewriter screen, so that you always can see what you write.
        Next time you see this happen, please take a screenshot of it and send it to us.  You do this on the iPad by pressing the home button and the power button simultaneously.
      • #144278
        Marcel
        Ok, I’ll do that.
    • #144279
      Marcel
      Yes, got one…rename preset….see pic.
      • #144280
        gkellum
        Cool, thanks.  We'll fix that in the next release.
      • #144281
        Marcel
        Great! Thanks! 🙂
      • #144379
        Marcel
        Yes! It is fixed in the new release I just downloaded. Great! Are there any new features?
        Some other bug I found (I use H9 Control for iPad):
        In ‘presets lists’ and in ‘presets’ mode you have at top right of screen: ‘more’. You there have the option : email. But nothing happens when you press that (this is the case in both modes).
        Now I work my way around it by exporting via settings, but….an option where nothing happens…is not really an option 🙂 So I think these are bugs.
      • #144388
        gkellum
        Marcel wrote:
        gkellum wrote:
        Some other bug I found (I use H9 Control for iPad): In 'presets lists' and in 'presets' mode you have at top right of screen: 'more'. You there have the option : email. But nothing happens when you press that (this is the case in both modes).
        I had someone else tell me about that problem but I couldn't reproduce it.  There were like 5 different versions of iOS 9.3.  So, maybe, it was specific to one of those versions?  In any case iOS 10 is out now.  I'll have to check if it's still happening in iOS 10.
        As a temporary work around, if you rotate your device from landscape to portrait orientation (or vice versa) and try again, that might help.  The problem seems to be related to the iPad's orientation.
      • #144392
        Marcel
        Tried it and you’re right: it works fine in portrait orientation. Thanks!
      • #144416
        Marcel
        Just updated my ios to ios 10, tested it and it is the same in ios 10 : email doesn’t work in landscape mode and does work in portrait mode.
      • #144570
        gkellum
        Marcel wrote:
        Just updated my ios to ios 10, tested it and it is the same in ios 10 : email doesn't work in landscape mode and does work in portrait mode.
        We just released a new version of H9 Control which should fix this problem.
        terich wrote:
        Is it possible to load this same menu in the MIDI mapping section?
        This is also in the new H9 Control release.
    • #144282
      terich
      Along with the name, the prefix would be great too (whether its a User preset or Factory preset, etc)
    • #144383
      terich
      Thank you so much! This feature makes my life much easier!
    • #144391
      terich
      • #144397
        gkellum
        I made a note about this.  It shouldn't be too hard to do.
    • #144629
      terich
      Thanks for this update! This is saving me tons of time at practice.
