Home › Forums › Products › Stompboxes › H9 Control, iPad crashes when saving lists or presets
- This topic has 5 replies, 2 voices, and was last updated 2 years, 1 month ago by
bohan
Eventide Staff.
March 16, 2023 at 2:24 pm #169768
Hi All,
I suddenly started experiencing the following issue. I’ve tried to outline reproduction steps here.
– Connect H9 to iPad via bluetooth
– start up H9 Control
– Navigate to an existing list local to the iPad
– add a preset to the end of the list
– choose “Save to iPad” (not “save to H9”)
Crash.
Note this only happens when the H9 is connected to H9 control on my iPad and I’m trying to save locally on the iPad. Saving to iPad works in “Demo mode” and saving to the H9 works when H9 is connected to iPad.
March 16, 2023 at 4:35 pm #169778
Also note: I installed H9 Control on my iPhone and experienced the same issue. In the case of the iPhone I was trying to add to a completely empty list. Both iOS devices are running iOS 16.3.1
March 27, 2023 at 6:09 pm #169937
Hi, you can update H9 Control in TestFlight. This new version has fixed the issue. You can join the beta at:
March 28, 2023 at 5:34 pm #169961
This is great, thanks for giving me access to the beta!
My issue is, indeed fixed with this build.
Unfortunately I haven’t been able to successfully import my saved presets (which I’d backed up as a .h9z file). When I attempt to import them via the settings on the iPad app, it says “no presets or preset lists were found to import”.
*Update* after killing the app and reopening it, all the imported lists are there (multiples of all of them because I guess every import worked, it just didn’t show up in the UI?)
March 28, 2023 at 5:41 pm #169962
ok, second update here: here is the only set of steps that seems to work to import:
from my computer (which has the h9z file), choose “share” > “Airdrop”
select my iPad from the list
when it pings my iPad choose “Open in H9 control”
nothing happens
kill h9 control
reopen H9 control and there are my lists!
hope this helps.
March 28, 2023 at 9:32 pm #169964
Thank you for the feedback.
