Home › Forums › Products › Stompboxes › h9 control lose bluetooth connection with crashed H9
January 29, 2015 at 11:49 pm #112293PerParticipant
It started to happen after the MAX upgrade. It freezes and I got to restart it to get going again, often when scrolling thru presets. Its closing in to liveperformance and I suppose H9 control is not to trust in a live situation. Not, that I think Im going to use it anyway. But who knows.
I pluged out the midi-cabel, the h-9 is synced via clock from drum machine, and it didnt crash on me after that, 45 minutes aprox.
Any advice, or information regarding this problem.
January 30, 2015 at 6:16 pm #127447
If you have not done so, you should probably re-initialize the unit. Also, make sure you are using the supplied power supply.
January 30, 2015 at 10:12 pm #127448PerParticipant
What do you mean with re-initialize the unit? Do you mean bluethooth, or something else? Ive done the turned off the bluetooth and re-initialized the device on the phone but the problem came back. The h9 never crash i when used without iphone h9-control.
Power-supply is the same supplied in the box.
January 30, 2015 at 10:32 pm #138142
Sorry – "Restore Factory System Settings", as described on UM p.45. You will have to re-do any system mode changes you have made.
January 31, 2015 at 7:14 pm #138147PerParticipant
Cheers, will try next time in the studio.
Will post feedback. I suppose you dont have to back up your presets, preset-list.
January 31, 2015 at 7:31 pm #138148
Per:
There are two versions – "Restoring Factory Presets and System Settings" will lose your presets (don't do this).
"Restoring Factory System Settings" is the one you want.
March 4, 2015 at 4:40 pm #138450PerParticipant
Feedback on this. Seems to worked out nicely. No more crashes.
