Home › Forums › Products › Stompboxes › H9 Control on Android 13
- This topic has 13 replies, 11 voices, and was last updated 1 year, 1 month ago by
omarschiavo.
September 24, 2023 at 11:31 pm #174313
Skyyyyy
ParticipantHi there,
I was looking to install h9 control on my pixel 7 running android 13. When i go to the play store is says ‘This app isnt available for your device because it was made for an older version of Android’
I was wondering if there was a new app to install? or if there was an update coming?
And apologies if this was address on another post, but i couldnt find an answer
Thanks,
A
September 25, 2023 at 10:19 am #174321
Sorry for the issues you are having. Can you please use the “H9 Control Android – Direct Download” from the link below and let me know if that works? https://www.eventideaudio.com/downloads/?product=H9+Max
November 9, 2023 at 12:51 pm #175564
lbrockkc
ParticipantGlad this forum exists!
Using the Direct Download, I was able to get H9 Control functional again. I had to uninstall the existing instance first, resulting in loss of all presets and lists stored on my phone but better than having no control at all.
October 3, 2023 at 12:31 am #174457
Skyyyyy
Participantawesome! works perfectly. Do you know if there is any plan to add it to the play store? just so it gets automatic updates and things like that?
October 9, 2023 at 12:14 pm #174571Inactive
I have the same issue but my Galaxy 22 was working fine with the h9 app. Now not. I downloaded the direct app but got a message that I don’t have an app that can open the file?
October 10, 2023 at 10:08 am #174591
fast-t
ParticipantApp was working great until the October surprise update. Now app crashes and cant find my devices. not an issue with my H9’s because I have several. Definitely not my phone it is a Flagship Z-Fold. Definitely an “Eventide app developer issue.” And did I mention I am an engineer by trade so I usually can get things to work without issue.
October 10, 2023 at 5:05 pm #174612
atewkesbury
ParticipantI have the same issue. I have a Samsung Galaxy A23 running Android 13. By default H9 control wasn’t discoverable on the Google play store, so i used the direct link to install.
But, it dosnt work. The H9 will bluetooth pair with the phone. But the app dosnt discover it – I get the message ‘Device not found!’. When i select ‘Search for Bletooth Devices’ the app just crashes. Seems to work in demo mode, but thats it.
October 14, 2023 at 2:38 pm #174820Inactive
My H9 android app also stopped working aftwr the latest update. The direct download app won’t even reinstall.
October 19, 2023 at 6:25 am #175002
tommetalmonkey
ParticipantThe direct download worked for me on Pixel 7 when the previous was crashing everytime it tried.to.connect to device. I also deleted all data prior to deleting the previous app in case that helped 🤷
November 5, 2023 at 9:36 pm #175445
axman53
ParticipantYep. Same experience here. Running Galaxy Tab S6 Lite, Android version 13, One UI version 5.1.1. After the most recent update, H9 crashes. Uninstalled, does not appear in Google Play store to install. Found this thread. Installed from the direct download and everything appears to be working. That was scary. When did drag and drop show up on Android??? I just noticed it.
November 18, 2023 at 8:09 am #175886
axman53
ParticipantI know all the stompbox attention right now is on the H90, but is there a committment on the part of Eventide to keep the H9 Control for Android app current with new Android releases? It seems that this thread has gone quiet and I’m wondering about that. I could not do a live show without being able to control my two H9s from my Android tablet. Any input from Eventide is welcome.
November 18, 2023 at 7:43 pm #175894
ccsu2240
ParticipantMy H9 Max has worked fine for over a year and for some reason the app keeps shutting down whenever I try to connect to the pedal via Bluetooth. It stays open only in demo mode. I restarted my phone and uninstalled/reinstalled the app. Same thing. Any help would be greatly appreciated. Thanks.
January 14, 2024 at 1:11 pm #177281
omarschiavo
Participant14 Jan 2024 and still doesn’t work the app via Bluetooth, not able to recall preset lists of the bands I play with.
