Home › Forums › Products › Stompboxes › H9 Control SW cannot connect via USB
- This topic has 7 replies, 5 voices, and was last updated 1 year, 4 months ago by
mxk145.
March 30, 2024 at 7:28 pm #180357
I wonder if others have seen similar issues.
The H9 control application (I’m running on Windows 10) worked perfectly with the H9 connected via USB port. This was fine just a few days ago.
Now, when attempting to open the app I get the following error consistently:
I unplug it, and followed the prompts to reset the settings and it works again for a session.
Then next time after unplugging and re-plugging the unit back in, or next day after PC shutdown and power-up, I get the same problem over and over – the unit will not connect.
I even re-flashed the FW which also made it come back again, but the same behavior continues – after a PC reboot or a pedal reboot communication to the desktop H9 control app is lost and I get these errors again.
The unit is not bricked fortunately because I am still able to control it via my phone and bluetooth, but using the app on the phone is a real PITA with such a small screen.
What should I do? Is it a failure of the current firmware? Should I reflash it to the prior version?
Just for extra info the unit appears in Windows Device Manager without any problems whatsoever, and is not dropping out or anything that would suggest a bad cable, and yes, I have the same behavior with multiple known-good USB cables and ports. This does not appear to be a hardware problem.
April 2, 2024 at 11:26 am #180420
Ditto. Same problem here. In fact, will not connect via bluetooth or usb when this error rears its’ head. And yes, having to do a Reset all too often is a PITA.
April 16, 2024 at 2:30 am #181046
I have the same problem with my two H9 Max, I was quiet working today and suddenly neither of them wanted to connect to the app again.
April 10, 2025 at 2:23 am #189500
Same. MAC Mini Monterey. USB 2.0 or USB C, neither work. Factory reset doesn’t change. Bluetooth performance flakey on Mac Mini. iPhone app has much better response.
Any resolution for this?
April 10, 2025 at 9:09 am #189509
Sorry for the issues you are having.
Some Macs running macOS 12 (Monterey) have known issues pairing with Bluetooth MIDI devices. If you are having trouble pairing your device on Monterey, updating to macOS 13 (Ventura) has been known to resolve these issues.
April 11, 2025 at 1:30 am #189528
Thank you very much for the prompt response. I have my H9 max in a rack system with Mac mini Monterey. I have many devices connected the the Mac via both USB and MIDI: QuPac, AxeFxIII, BomeBox, and H9. I would prefer to use the USB connection on the H9 because it is only one click of the app icon. Whereas, the bluetooth connection requires multiple connection steps. Do you know a solution for the USB connection issues? Will macOS 13 solve this?
April 11, 2025 at 12:30 pm #189534
What exactly is happening when you attempt to connect via USB? Can you select “manually select a device” in the app?
Please try connecting directly to the computer without a USB hub.
April 14, 2025 at 12:20 am #189548
I get the same error message as xjordanx posted. Except, with my serial number. I am plugging USB cable directly from the Mac mini to the H9, no hub.
April 14, 2025 at 12:20 am #189549
