H9 Control v2.0.1 Windows app
Home Forums Products Stompboxes H9 Control v2.0.1 Windows app
    • #112109
      Styrioci
        Hello, I just found some strange behavior of latest version of H9 Control SW for Win.
        Win7 x64 pro
        H9 Control v2.0.1
        Audio Interface Native Instruments Komplete Audio 6 with latest drivers
        H9 with latest FW
        symptoms:
        I have H9 connected via MIDI to my audio interface and that goes via USB to my Laptop. Worked fine until I upgraded H9 Control app to latest version and H9 FW as well. When I have it connected via midi and audio interface and I start H9 control app it crashes immediately. Same when I have connected audio interface (with MIDI cables disconnected) and H9 connected via USB to my laptop. H9 Control app works fine when H9 is connected via USB with no other devices plugged in via USB.
        What I have tried – H9 FW downgrade to previous version, reinstall H9 Controll app, reinstall audio interface driver  – with reboots after each SW (un)install, no help. So it seems it's H9 Control app for Windows which is causing problems.
        There are following events logged in app event logs.
        Log Name:      Application
        Source:        Application Error
        Date:          26. 11. 2014 14:29:58
        Event ID:      1000
        Task Category: (100)
        Level:         Error
        Keywords:      Classic
        User:          N/A
        Computer:      StyriOci-PC
        Description:
        Faulting application name: H9 Control.exe, version: 2.0.1.0, time stamp: 0x546f90db
        Faulting module name: H9 Control.exe, version: 2.0.1.0, time stamp: 0x546f90db
        Exception code: 0xc0000005
        Fault offset: 0x0002eefa
        Faulting process id: 0x948
        Faulting application start time: 0x01d0097d129957e3
        Faulting application path: C:Program Files (x86)EventideH9 ControlH9 Control.exe
        Faulting module path: C:Program Files (x86)EventideH9 ControlH9 Control.exe
        Report Id: 508d25d3-7570-11e4-be0b-20cf30d0caf1
        Event Xml:
        <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"&gt;
          <System>
            <Provider Name="Application Error" />
            <EventID Qualifiers="0">1000</EventID>
            <Level>2</Level>
            <Task>100</Task>
            <Keywords>0x80000000000000</Keywords>
            <TimeCreated SystemTime="2014-11-26T13:29:58.000000000Z" />
            <EventRecordID>43088</EventRecordID>
            <Channel>Application</Channel>
            <Computer>StyriOci-PC</Computer>
            <Security />
          </System>
          <EventData>
            <Data>H9 Control.exe</Data>
            <Data>2.0.1.0</Data>
            <Data>546f90db</Data>
            <Data>c0000005</Data>
            <Data>0002eefa</Data>
            <Data>948</Data>
            <Data>01d0097d129957e3</Data>
            <Data>C:Program Files (x86)EventideH9 ControlH9 Control.exe</Data>
            <Data>508d25d3-7570-11e4-be0b-20cf30d0caf1</Data>
          </EventData>
        </Event>
        Source:        Windows Error Reporting
        Date:          26. 11. 2014 14:30:08
        Event ID:      1001
        Task Category: None
        Level:         Information
        Keywords:      Classic
        User:          N/A
        Description:
        Fault bucket 671410942, type 17
        Event Name: APPCRASH
        Response: Not available
        Cab Id: 0
        Problem signature:
        P1: H9 Control.exe
        P2: 2.0.1.0
        P3: 546f90db
        P4: H9 Control.exe
        P5: 2.0.1.0
        P6: 546f90db
        P7: c0000005
        P8: 0002eefa
        P9:
        P10:
        C:UsersStyriOciAppDataLocalTempWERC0A0.tmp.WERInternalMetadata.xml
        These files may be available here:
        C:UsersStyriOciAppDataLocalMicrosoftWindowsWERReportArchiveAppCrash_H9 Control.exe_56e2abd9d19f934b39bb41b4fefea3d623086d2_0284e7a1
        Analysis symbol:
        Rechecking for solution: 0
        Report Status: 0
        Event Xml:
          <System>
            <Provider Name="Windows Error Reporting" />
            <EventID Qualifiers="0">1001</EventID>
            <Level>4</Level>
            <Task>0</Task>
            <TimeCreated SystemTime="2014-11-26T13:30:08.000000000Z" />
            <EventRecordID>43089</EventRecordID>
            <Security />
          </System>
          <EventData>
            <Data>671410942</Data>
            <Data>17</Data>
            <Data>APPCRASH</Data>
            <Data>Not available</Data>
            <Data>0</Data>
            <Data>
            </Data>
            <Data>
            </Data>
            <Data>
        C:UsersStyriOciAppDataLocalTempWERC0A0.tmp.WERInternalMetadata.xml</Data>
            <Data>C:UsersStyriOciAppDataLocalMicrosoftWindowsWERReportArchiveAppCrash_H9 Control.exe_56e2abd9d19f934b39bb41b4fefea3d623086d2_0284e7a1</Data>
            <Data>
            </Data>
            <Data>0</Data>
            <Data>0</Data>
          </EventData>
        </Event>
      • #127045
        gkellum
          Hm… We'll have to see if we can reproduce that.  Hopefully, we won't need a Audio Interface Native Instruments Komplete Audio 6 to do so.
          You mentioned that H9 Control is crashing even when it isn't connected through your MIDI interface if that MIDI interface is connected. I think you could get rid of that problem by erasing the setting that causes it to try to connect to your H9 through the MIDI interface.  You can reset all the app settings by clicking on the Settings button in the bottom right hand corner of H9 Control and going to Reset Settings and using the reset all settings function.  After you do this, when you restart H9 Control with your device connected (via USB), you're going to need to enter your user name and password again to verify your registration info, but hopefully after you do this, you'll be able to connect your devices via USB without it causing anything to crash.
        • #127051
          Styrioci
            reset settings procedure worked wonderfully, nothing crashes now 🙂 many thanks for hint
