Home › Forums › Products › Stompboxes › H9 Control v3.6 for Android crashing when I try to import presets
August 9, 2019 at 6:06 pm #115461joshofsortsParticipant
Every time I try and import a *.h9z or any other type of preset file, my Android H9 Control v3.6 crashes on me. Anyone else having this issue?
What Android device are you using? I'm trying to fix this problem. Is your Eventide account same as your Google Play account? If so, I'm gonna make a beta version for you so you may test if it fixes this issue.
August 16, 2019 at 8:22 pm #152548joshofsortsParticipant
Here is an example, but I have tried more than one file.
August 23, 2019 at 2:42 pm #152605
There is something wrong with the file handler in Android. When you import the file from the "Downloads" folder directly, it cannot solve the handler of that file. However, if you go to your "Internal Storage"->"Download", which has the same files as the "Downloads" has, and then select a preset file, it would work.
August 28, 2019 at 5:14 pm #152646joshofsortsParticipant
That works, thanks!
Could you censor out my email address from the earlier post? Thanks.
August 19, 2019 at 3:46 pm #152565joshofsorts wrote:Here is an example, but I have tried more than one file.
I can import this preset list on my android devices. In which folder do you store this file on your phone? When you click "Import Preset List" and select the file, do you see any message or dialog?
August 28, 2019 at 6:52 pm #152648joshofsorts wrote:
That works, thanks!
Sure. I deleted that post
