H9 controlled with a Bluetooth MIDI pedal
Home Forums Products Stompboxes H9 controlled with a Bluetooth MIDI pedal
Viewing 3 reply threads
    • #174603
      valentini
      Hi all,
      is it possible to send MIDI messages (Program change and Control Change) froma a Bluetooth MIDI pedal to an H9, through Bluetooth?
      I am trying to do it with a cheap M-VAVE Chocolate BT Wireless MIDI Controller.
      thanks!
      -Antonio-
    • #174606
      The M-Vave Chocolate will not be able to pair directly to the H9 via Bluetooth.
      You may be able to get it to work with the Bluetooth  > DIN MIDI adapter, but this is not something I have tried – https://m-vave.com/products/m-vave-midi-system-ms1
    • #174607
      valentini
      Thanks, you confirm what I suspected!
      I will try with the MIDI DIN adapter.
      Thanks again,
      -Antonio-
    • #176993
      lorenzolamberti
      hi antonio ! i was thinking to buy the same. did you have any luck with the Bluetooth midi adapter? thanks 🙂
