H9 – Controlling Volume with express pedal in a defined range (e.g. from 0bd to +2db)
Home Forums Products Stompboxes H9 – Controlling Volume with express pedal in a defined range (e.g. from 0bd to +2db)
Viewing 4 reply threads
    • #115375
      Hi everybody
      I would like to control the volume parameter of each preset with the expression pedal in the same way I’m controlling the other parameters (e.g. adjusting at the same time the amount of the mix and increasing the volume from 0 to +2db). Is it possible?
      It seems volume is the only parameters that cannot be adjusted with the expression pedal from one value to another (e.g from 0db to +3db)
      As far as I know Eventide planned to “solve” this issue some years ago so I’m wondering if there is some progress about this topics.
      Thankyou
      Emanuele from Italy
    • #152134
        lele77 wrote:
        Hi everybody
        Thankyou
        Emanuele from Italy
        +1
      • #152143
        camn
          gods please this would be incredible
        • #152242
          Anyone from Eventide??
        • #152256
          camn
            like, for real this would be so clutch
