H9 core expression pedal programming
Home Forums Products Stompboxes H9 core expression pedal programming
    • #115340
      raymondgsmith
         my issue is when programming the H9 for controlling specific parameters, somehow the expression pedal when all the way to toe down position puts the preset in bypass mode, then when in heel position, it becomes active again. how can I change this so that its active from toe to heel.
      • #152007
        bohan
          See my attached screenshot. Make sure you choose "Expression Pedal" for this setting.
