Home › Forums › Products › Stompboxes › H9 Core Noob Q: are purchased algorithms automatically stored to my H9?
August 25, 2016 at 1:22 pm #113657LukeGibsonMember
I purchased a couple algorithms for my H9 Core and they are on my H9 Control app on my iphone but I assumed they would automatically be loaded to the H9? Do you have to send them to the H9?
Thanks and apologies if this was already asked!
Peace,
Luke
If your H9 is connected to H9 Control when you make a purchase (and at least one H9 has to be connected for you to be allowed to make a purchase), then the algorithm will automatically be installed on the H9. If it wasn't connected you can always use the Restore Purchases function in H9 Control under Settings to resync your H9 with our server.
In your case you were probably expecting a bunch of the algorithm's presets to appear on the H9. That we don't do. Since the H9 is limited to 99 presets, we would have to overwrite existing presets to make way for new presets. So, you have to save presets for your new algorithm to the H9 using H9 Control.
You can also always call up the new algorithm by pressing the Preset switch twice. Then the big black wheel will scroll through the list of algorithms instead of presets.
August 25, 2016 at 9:07 pm #144196LukeGibsonMembergkellum wrote:LukeGibson wrote:
If your H9 is connected to H9 Control when you make a purchase (and at least one H9 has to be connected for you to be allowed to make a purchase), then the algorithm will automatically be installed on the H9. If it wasn’t connected you can always use the Restore Purchases function in H9 Control under Settings to resync your H9 with our server.
In your case you were probably expecting a bunch of the algorithm’s presets to appear on the H9. That we don’t do. Since the H9 is limited to 99 presets, we would have to overwrite existing presets to make way for new presets. So, you have to save presets for your new algorithm to the H9 using H9 Control.
Thank you very much for the information. I did see the algorithm I purchased on the H9, I wrongly assumed the patches would be loaded to my H9. I ended up just saving them as presets to play around with, again much thanks!
Luke
