H9 Delete Presets
Home Forums Products Stompboxes H9 Delete Presets
Viewing 5 reply threads
    • #111484
      g.lolo3
      How can I delete all the presets into the H9 so that I have a empty pedal?
    • #125605
      gkellum
      Unfortunately you can't.  You can overwrite presets, and you can limit the preset range so that the pedal only scrolls between the range of presets you want to work with though.
    • #125616
      g.lolo3
      Thanks I agree the presets limit function do the trick when playing.
      But when saving/organizing presets I think it is a lot easier to see the "+ Click Here to Add Preset" in H9 control or the "—-" preset name on the H9 instead of reading the name and remember if we use it or not.
    • #136330
      g.lolo3
      Moreover there is the "Delete Preset" in the list editor.
      It works for Computer Lists but not for H9 list. A bit confusing…
    • #136338
      gkellum
      g.lolo3:
      What do you mean that "Delete Preset" doesn't work for the H9 list?  It certainly should.  When you delete a preset directly on the H9, it should shift every preset above that preset down by one.  But if there isn't anything assigned above the current preset it will appear that nothing has happened though.
    • #136352
      g.lolo3
      I agree but I was meaning "completely and cleanly" delete a preset.
      So that in H9 Control I can see "Click Here to Add Preset" and on the H9 I cannot go
      over the last "not empty" preset. Like when I get my H9 Core v4.5. There are only 25 presets.
      I cannot go over 25 even if the Preset/max is at 99. When I save a new preset in a number over
      25 it automaticly skip from 25 to the preset number I create.
      Anyway I agree we can live without this but I like to have things clear. And delete a preset seems to be
      an "obvious" feature to me…
