H9 Dough Wimbish sound
Home › Forums › Products › Stompboxes › H9 Dough Wimbish sound
    • #115275
      Paradox
        Look at this video at min 3:00:
        https://www.youtube.com/watch?v=XTpioN2g7Bg
        I don’t know if this sound is made with the H9 only. Someone can help me in order to reproduce it?
        Many thanks, bye
      • #151691
        bohan
          I don't know if this sound is made with the H9 only. Someone can help me in order to reproduce it?
          Sounds like 3 octaves up + some reverb. You may use H910/H949, PitchFlex, or PitchFuzz to do that.
        • #151692
            Agreed.  You could probably use any of those algos.  I heard 2 octaves up, though, from where he was on the fretboard.  The shifted timbre & the initial glide screamed PitchFlex to me.  As in ’embracing the glitch’, and using phrasing & vibrato to transform it into something expressive.
            I don’t know how he engaged the effect.  If it was by the FLEX / auxiliary switch, it’s probably a latching one.  In that case, dial up the H-T GLISS for the initial glide.  Expression pedal works (used for the preset above).
            Using expression, the H-T GLISS, T-H GLISS, and SHAPE values don’t really matter.  It’s a bright sound, so I left the LP FILTER at minimum. If you don’t have an expression pedal (just want that sound, without the glide), dial up the HotKnob to 100.  Use ACTIVE / (BYPASS) to maintain your original tone.
            All that said, I’ll bet the H910 / H949 algo would be very close, especially using one of the olders TYPEs.
