H9 DSP+FX bypass doesn’t Work
Home Forums Products Stompboxes H9 DSP+FX bypass doesn’t Work
Viewing 7 reply threads
    • #113077
      Tomviolet
      As the title says, after last update My H9 and started to use the pre/post function, bypass doesn’t work proeprly.
      When I set DSP+FX it doesn’t work. The trails are completely cut off when I bypass the pedal?
      How can I fix this? Or what should I check?
    • #141751
      Sorry you are having trouble. In order for us to help you, please tell us:
      1) What are your connections ?
      2) In what way does it not work ?
      • #141757
        Tomviolet
        1) H9 is connected to a midi looper switcher in 2 slots (pre/post)
        2) Everything works like charm except from the DSP/Fx bypass. when i turn off the pedal from MIDI or even from H9 footswitch itself  effect trails are instantly cut off as if the pedal is in hard or dsp bypass mode
      • #141768
        gkellum
        It would be good to try resetting your H9s system settings by turning it off and turning it on again with the right footswitch and the HotKnob pressed (the button in the upper left hand corner of the H9).  The last update seems to require that the system settings be cleared.
      • #141769
        Tomviolet
        Thank you gkellum,
        I’ve tried to reset the pedal as you suggested. Trails worked until I’ve set again the pedal in Pre/post routing.  With h9  set in that routing  DSP+FX doesn’t work. The fx trails are immediatly cut off. 🙁
        Could you check this with other units?
      • #141770
        gkellum
        Sure.  Will do.
    • #141771
      gkellum
      Ok, we could reproduce this.  So, it's a bug in the H9 software.  Thanks for bringing it to our attention.  We'll look into.
    • #141772
      Tomviolet
      Thank you very much! So I’ll wait for the next update for this fix!
    • #142014
      homeless
      I’m having this same issue.  Glad it’s on their radar!!!
    • #153183
      Mr.Echo
      Buongiorno, ho anche io questo problema. Software installato 5.8.2.
      Sono in modalità dsp+fx e al cambio prest oppure al bypass mi vengono tagliate le code dei delay…
      Suggerimenti?
      Grazie
    • #153188
      Google says:
      Hello, I also have this problem. Installed software 5.8.2.
      I am in dsp + fx mode and at the change preset or at the bypass the tails of the delays are cut …
      Tips?
      Thanks
    • #153189
      This issue has been posted several times recently and many times in the past.
      The purpose of DSP+FX is to allow effect tails to be heard when the unit is bypassed. It is possible that this does not function in PRE/POST mode – don't know at this time.
      As Mr Bohan mentions in another post, the unit does not allow a tail to continue when another preset is loaded. This is because each preset takes up all the abilities of the machine, and when you load a new preset, the previous one is GONE.
      The SPACE has a SPILLOVER feature, that does allow the tail of the previous effect to be heard, but this is only possible because all the effects are similar (i.e. reverbs), and do not use all the machine's resources. This is not the case on H9.
      Questo problema è stato pubblicato più volte di recente e molte volte in passato.
      Lo scopo di DSP + FX è quello di far sentire le code degli effetti quando l'unità viene bypassata. È possibile che ciò non funzioni in modalità PRE / POST – al momento non lo so.
      Come menziona Mr Bohan in un altro post, l'unità non consente a una coda di continuare quando viene caricata un'altra preimpostazione. Questo perché ogni preset prende tutte le capacità della macchina e quando carichi un nuovo preset, il precedente è ANDATO.
      SPACE ha una funzione SPILLOVER, che consente di ascoltare la coda dell'effetto precedente, ma ciò è possibile solo perché tutti gli effetti sono simili (vale a dire riverberi) e non utilizzano tutte le risorse della macchina. Questo non è il caso di H9.
