H9, Empress Reverb, Boss ES-8 Midi Thru Help
Home › Forums › Products › Stompboxes › H9, Empress Reverb, Boss ES-8 Midi Thru Help
    • #113957
      markroskowske
        I’ve been trying to get the H9, Empress Reverb and Boss ES-8 to talk to each other.  I can control the Empress fine when it is plugged in o the ES-8 directly.  However, when I add the H9 before it, I can’t get it to work.  I have the H9 on channel 2 and the Empress on 3.  The H9 works fine when connected directly to the ES-8.  I have the Midi set to Thru+CC.  I also tried Thru.
      • #145494
          When you have multiple complex units connected together it is usually impossible to give a remote diagnosis. You may need to find a good technician.
          Also, you don't actually say what the problem is – in what way does it "not work" ?
          If your problem is that you are not receiving MIDI, things to try are:
          1) Use the very latest software in the H9 – this has some MIDI improvements.
          2) Re-initialize the H9 as described in the UM.
          3) Set MIDI channel numbers temporarily to OMNI, just in case there is a mis-match.
          4) Don't use THRU+CLK or MERGE if you have heavy MIDI traffic.
