Is it possible to adjust the sensitivity of the encoder on the H9, it takes over 4 full rotations to get the from 0-100 on any of the parameters. Is it possible to edit this so it is a single 360 degree rotation to go from 0-100?
Apologies if this has been addressed somewhere, but i had a dig around and couldnt find it.
While the H9 does have the capability of changing the encoder’s sensitivity from coarse adjustment to fine-tuning by pressing the knob while searching, there isn’t a setting where it’ll give you the full range of control with one rotation of the knob. Such a sensitivity would be too coarse for most available parameters. The only other alternative I can think of involves mapping parameters to an external expression knob or pedal.
