H9 Eq Compressor. Adding sustain
Home Forums Products Stompboxes H9 Eq Compressor. Adding sustain
    • #113457
      danisev2001
      Hi all,
      I would like to add sustain to my solos with the H9 Eq compressor algorithm. How should I set the parameters?
      Thanks in advance, Daniel.
    • #143396
      wedelich
      You should be able to simply turn the Compression knob up pre or post EQ.  You might also want to juice up certain frequencies using the EQ to pull them out for solos.
