H9 exp pedal and aux switch issue
Home Forums Products Stompboxes H9 exp pedal and aux switch issue
    • #170459
      lander4002
      I have my H9 connected to an Ampero switch and a Moog exp pedal. I have tried them both separetely and there is no issue with none of them. The problem begins when i want to use them together as the rigth switch stops working (the left switch does increase the presets).
      I have checked the Y cable and it works fine as so does the exp pedal and the switch by their own.
      Any ideas of what could Im doing wrong?
    • #170472
      joecozzi
      When the H9’s aux input is set to BOTH mode, we can only use one aux switch and an expression pedal. The Ampero switch has two buttons, so you’ll loose functionality of he second switch.
