H9 Expression pedal calibration problem
Home › Forums › Products › Stompboxes › H9 Expression pedal calibration problem
    • #172517
      sulley
        I have a problem with my H9 and an expression pedal (Ernie Ball VP jr.). I connect it with a Y-cable and I can calibrate it quite normally so that it reads from 0 to 100. Works great. After that I block the calibration in the App. When I plug in the pedal next time, the range is only from 0 to 49 and I can’t change that. Does anyone have an idea how to solve the problem? Is it possible to connect two different expression pedals (Ernie Ball) and calibrate them so that they always have full control range?
      • #172528
        sulley
          Problem solved, cable was broken.
