H9 Expression Pedal Plug Issue
Home Forums Products Stompboxes H9 Expression Pedal Plug Issue
    • #113622
      Ha anyone had issues with the TRS plug not going all the way in the pedal? It has worked perfectly for me for months then only allowed the plug to go in ~ 80% of the way. The plug sticks out ~ 1/4 inch more than normal. Thanks
    • #144095
        Not a known problem. I would suggest that you try an entirely different cable.
      • #144096
        The problem turned out to be the tip of a cheap TRS plug. The H9 is now working perfectly after disassembling it to extracted the tip.
        Thanks for the direct replies
