H9 External Tap not working when heel down
Home Forums Products Stompboxes H9 External Tap not working when heel down
Viewing 6 reply threads
    • #172326
      dtmcinto
      Hi there,
      I bet this is something Ive done…
      Ive got a DOD expression pedal and MXR tap on the Aux of the H9 and all works great.  Ive tried to change the external tap from performance switch to tap tempo but it only works when the heel is down on the expression pedal.
      Im getting I’ve got a setting wrong in the pedal/control app?
    • #172403
      dtmcinto
      Anyone know if its due to an incorrect setting?
    • #172410
      Sorry for the issues you are having.
      In H9 Control, can you go to Pedal Settings > General Settings > Use Expression Pedal, Aux Switch, or Both and set this to Both?
      Are you using a Y-cable to connect both devices to the H9?
    • #172411
      dtmcinto
      Thanks of your help!  Yes, I already have that set to Both.  I used to have the mxr tap set for the hotswitch and that worked fine.
    • #172412
      dtmcinto
      p.s. DOD expression is set to TS mode
    • #172423
      dtmcinto
      Is there anything else I should try?
    • #172503
      dtmcinto
      Hi, still really hoping to get this issue fixed
      thanks!
