Home › Forums › Products › Stompboxes › H9 failure
May 4, 2016 at 12:09 pm #113437DucatipowaMember
Hello Tim here not new to eventide but have a new (2 month ) old h9 max that decided to go into update mode on its own. I was pushing both bottom switches to get to tuner and when I looked down it said update. I’ve tried resetting it per instructions on app when it would not connect to iPad. Came home downloaded h9 control on Windows and tried to connect usb. Now it was ready still stuck
I need this resolved I built my entire pedal board around this unit. -
May 4, 2016 at 3:07 pm #143274
Hi Tim. Sorry you are having trouble. Here are some things to do (in order):
1) Try and get the dealer to exchange it for another. If he is not keen…
2) The "HOTKNOB" switch may be jammed. Try and wiggle it a bit. If no good…
3) Power up the unit with the left footswitch held down. This will put it into test mode. Release the key – it should say "01 Test…" If any key is stuck, it will say "Test 4.6" or similar for about 5 seconds, then it will show "K_xxxx", where xxxx is the name of the key. If this is not the case…
4) Try and update it using Eventide Direct Updater over USB (see H9Control for more info). If no good…
5) Contact support@eventide.com, giving your purchase info and serial number.
May 4, 2016 at 3:57 pm #143277DucatipowaMember
Yes I have tried to connect using usb the unit switched to ready then stuck in ready
I have tried all things suggested. I bought it brand new from a dealer on eBay. Less than months ago. What do I have to do to get this unit repaired I’m not interested in pointing fingers just need my gear online. I really hope I didn’t get screwed on a 800 pedal. -
May 4, 2016 at 4:03 pm #143278DucatipowaMember
The unit went into update for no reason. I’ve summited a form please help.
May 4, 2016 at 4:09 pm #143279Ducatipowa wrote:The unit went into update for no reason. I've summited a form please help.
Don't understand. Hopefully you mean you followed step (5).
May 4, 2016 at 8:04 pm #143281DucatipowaMember
Thank you Jerome for monitoring and getting to me .
