Home › Forums › Products › Stompboxes › H9 Firmware Update Errors?
October 26, 2013 at 4:20 pm #111169mld530Participant
Hi guys:
Today, my iPad prompted me to download an updated version of the control app, and I was excited to see the new update with the Resonator algo. Unfortunately, I have not been able to install it without problems.
Everything seems fine at first – the firmware downloads, and I get the screen prompting me that I;ll have to restart the app, establish a new bluetooth connection, etc. However, at that point, the H9 flashes the words "Update," "Bad", and "Erase," and crashes. On another attempt, the H9 simply flashed the letter "I" after downloading the firmware, and was non-functional. Help!
October 26, 2013 at 5:50 pm #124945
Sorry that you're having trouble updating your H9. It seems that for some reason the updated firmware is corrupted. Try powering up while pressing and holding the hotswitch button. This will put the unit in a manual update mode. Cycle power once more (without holding down the button) and the H9 should revert to the last firmware. At that point you can try updating once again.
October 26, 2013 at 6:48 pm #124946mld530Participant
Ok, will try that when I get home and report back. Thanks for the prompt response.
October 26, 2013 at 11:09 pm #124947mld530Participant
Tried that – no luck. I got the same "update" "bad" message after downloading. What else should I try?
October 26, 2013 at 11:10 pm #124948mld530Participant
Unfortunately, that didn't work. What else can I try?
October 27, 2013 at 12:57 am #124949mld530Participant
Also – I downloaded the H9 Windows control app to see if maybe it was a iOS or Bkuetooth issue. Same thing – downloading is fine, but when it tries to install, I still get "update, bad, erase," and a shutdown.
October 27, 2013 at 2:15 am #124950gkellumParticipant
Ok, after you restart the H9 with the HotKnob pressed and restart it again, it boots up fine though, correct? It's the updating that's giving you problems, but you can still relaunch the H9 with the previous firmware without any problems, right?
We have an alternative mechanism for updating the H9s, and I'd like to have you try that instead. I think we probably want to give you a slightly different update file than the one on the server, because I think we want to update not only your H9's OS but another component as well. I am going to need a colleague of mine to put this together for you on Monday. So, I hope you don't mind me asking you to wait until Monday, and I'll send you an email to the email account you have registered with us about that.
October 27, 2013 at 2:50 am #135754mld530Participant
That's right – it works fine when not in the update process. Sounds great – will look forward to hearing from you on Monday. Thanks again.
January 21, 2014 at 10:25 pm #136092bigbeat16Participant
Hi I'm having the exact same problem your describing with my H9 crashing during 4.4.6.1 installation. Were you ever able to resolve it with the file he sent you? Thanks.
January 21, 2014 at 10:43 pm #136093gkellumParticipant
I think we did resolve his problem. Please send an email to support@eventide.com describing the problem and we'll send you our alternative update utility.
