What have you tried, and how is that different from what you’re after?
I’ll guess that it’s the [F1] H3000 MICROPITCH preset? That one’s a bit shallow, and 100% wet. I’m not sure what the parameter values would be on the original H3000 preset – the one using the Layered Shift algorithm.
The H9 / PitchFactor’s MicroPitch structure looks very similar, and should cover most any of it. So should the H910 / H949 algorithm. If you need wider pitch shifts, the HarModulator algo would be a good choice.
