H9 How assign XYZ in iOS app?
Home Forums Products Stompboxes H9 How assign XYZ in iOS app?
Viewing 4 reply threads
    • #114247
      ufodesign65
        I know how in desktop app but how to do it in iOS or without any app just on the pedal?
      • #146729
        gkellum
          On iOS you can double click on any control to bring up a popover dialog where you can make that assignment.
          On the H9 itself you can long press any of the switches to put them in Expert mode and then pressing the switch cycles through the available parameters.  When you save a preset, it will save what parameter was currently showing for each of the three switches.
          • #150034
            minor7th
            • #150035
              bohan
                You may press and hold the HOTSWITCH (the button in the middle), then you should be able to set the Hotswitch mappings, and press it again to confirm the setting.
            • #156641
              vichightaian
                so is there an xy pad within the app?
              • #156642
                joecozzi
                  Yes.
                • #156647
                  vichightaian
                    I posted in the wring section.  I was referring to the standalone iOS effects apps.  I sent an email and was informed those do not have an xy pad.  bummer
