New Owner
I see that most of the reverb algorithms are stereo. I'm running the h9 at the end of my signal chain going into the amp. Channel one is TRS and channel 2 is also clean.
To get the best Hall reverb:
1-Run Mono in
2-Use Y cable with 2 TS and 1 TRS to run from both outputs using TRS into the amp
3-Run into both channels
4-A mono algorithm that does Hall
