I'd like to know if it is possible to configure the H9 to output dry on one channel and the other channel wet.
The reason I'm asking about this is that although I typically only use one channel of my H9, sometimes I'd like the H9 in my amp's effects loop, and other times I'd like it in front of the amp.
If it were possible to only effect either the L or R channel, I could put one channel before the amp and the other in the loop, and then set the preset to effect one channel or the other depending on what I wanted at the time.
I wouldn't mind if the non-effected channel was not bypassed, as long as it passed the dry signal through to its output.
If this is not possible, perhaps you could add it to the wish list?
