H9 latency (AD/DA conversion)
Home Forums Products Stompboxes H9 latency (AD/DA conversion)
    • #186544
      zbertch
        What is Eventide’s official latency measurement for the H9? The H90 specs are listed in the user manual and have been discussed on this forum, but I’m not seeing the same for the H9.
      • #187190
        Milliampere
          I have the same question. There should be a reply on this one ……
        • #187191
          zbertch
            I did a little more digging and saw that in the H90 manual it says “When using an Eventide H9, set the insert latency to 109 samples.” The H90 runs at a 48 kHz sample rate, and latency equals buffer size in samples divided by sample rate. If my logic is correct, that would amount to H9 latency of 2.27 milliseconds. Incidentally that’s much better than the H90 even when the latter is in parallel routing mode with no inserts.
