H9 Line Level
Home › Forums › Products › Stompboxes › H9 Line Level
    • #111211
      I just picked up a H9 yesterday, I've been using a Space pedal since it was released and love it to death.
      My setup with the Space was simple, I run into the effects loop of my HD500, Set the Space rear switches to Line Level,  Go to Go.
      I had a Timefactor back before the space as well, and the setup was the same.
      So I get the H9 (and unfortunately sold my space), There are no Line switches, I am playing around with the input and output levels, but it does not sound at all the same as the Space.
      I've matched my Space patches to be identical in the H9 with the editor.
      So I guess the question is going to be, How to I set the H9 Inputs and Outputs to be the same as the other Factor pedals when they are set to LINE?
    • #125036
        As you have spotted, H9 does not have line inputs. It will handle a hot guitar, but can be overloaded if you give it a high level line input.
