Home › Forums › Products › Stompboxes › H9 Max Amp Setup
- This topic has 6 replies, 2 voices, and was last updated 2 years, 3 months ago by highvoltagemusic.
October 8, 2022 at 6:36 pm #165935highvoltagemusicParticipant
Hi
I just bought the H9 Max and I have a Boss Katana 100 MKII. What’s the best signal chain in front of the amp of effects loop?
October 8, 2022 at 6:46 pm #165936
Congrats on your new purchase. I’m not sure what you’re asking. Do you want a recommendation as to how to connect H9 to the from of the amp or do you want recommendations on the types of effects that are useful in the effects loop?
October 8, 2022 at 6:52 pm #165938highvoltagemusicParticipant
Hello, Congrats on your new purchase. I’m not sure what you’re asking. Do you want a recommendation as to how to connect H9 to the from of the amp or do you want recommendations on the types of effects that are useful in the effects loop?
How to connect to my amp.
October 8, 2022 at 7:00 pm #165939
There are three options:
option 1 – Guitar goes to input one on the H9, from output, one on the H9 to the front of your amp. If you tend to run your amp clean, this will work just fine. However, if you are going to be using the distortion of your amp. It’s best to connect the H9 to the effects loop.
Option 2 – Connect your guitar directly to the amplifier. From the amp’s effects loop Send connect to input one of the H9. From output one of the H9 connect to the amps effects loop Return. This is a common configuration, but works best with time-based affects like delays or Reverb’s. I would not be using gain-based affects like distortion here.
Option 3: use H9’s pre-post mode to be able to direct signal to the front of the app when algorithms are set to PRE and direct signal to the effects loop when algorithms are set to POST. This videos explains PRE/POST mode: https://m.youtube.com/watch?v=46_-T7emyjw&list=PLhT2MsSeKiDw6X56B_cfGPhD4GeBd3MA4&index=32
October 16, 2022 at 4:08 pm #165998highvoltagemusicParticipant
Never mind the video you attached answered my question. Thanks!
October 8, 2022 at 7:02 pm #165940highvoltagemusicParticipant
Joe,
I think option 2 will be the best option.
October 16, 2022 at 3:49 pm #165997highvoltagemusicParticipant
There are three options: option 1 – Guitar goes to input one on the H9, from output, one on the H9 to the front of your amp. If you tend to run your amp clean, this will work just fine. However, if you are going to be using the distortion of your amp. It’s best to connect the H9 to the effects loop. Option 2 – Connect your guitar directly to the amplifier. From the amp’s effects loop Send connect to input one of the H9. From output one of the H9 connect to the amps effects loop Return. This is a common configuration, but works best with time-based affects like delays or Reverb’s. I would not be using gain-based affects like distortion here. Option 3: use H9’s pre-post mode to be able to direct signal to the front of the app when algorithms are set to PRE and direct signal to the effects loop when algorithms are set to POST. This videos explains PRE/POST mode: https://m.youtube.com/watch?v=46_-T7emyjw&list=PLhT2MsSeKiDw6X56B_cfGPhD4GeBd3MA4&index=32
Hi I have my H9 going to the effects loop but I would like to add a delay pedal. I have the eventide micropitch what connections do I have to make and do I need to chage any setting in the H9? Thanks
