H9 Max Bluetooth Paired led
Home Forums Products Stompboxes H9 Max Bluetooth Paired led
    • #112828
      Claudiobass7
      Hi, In my H9 Max the Bluetooth Paired led dosen’t work and the Signal clip led is light. Do you have a solution? Thank!!! Claudio
    • #140619
      Hi Claudio
      You say the Bluetooth pairing light does not come on.  Does the Bluetooth itself work ?
      Is the signal clip light on all the time, even with no signal ?
      If the answer is yes, you should contact support@eventide.com
