Home › Forums › Products › Stompboxes › H9 Max problems – Not turning on sometimes
March 18, 2016 at 2:43 pm #113345
HugoScaramal
ParticipantHi, I just got an H9 and I’m having problems with it.
As soon as I got it, I went ahead and updated the firmware via bluetooth to the latest version (5.3.0) and the process worked just fine.
But then I started to notice that in some cases when I plugged it in the eletricity, it didn’t turned on at all.
No lights, no nothing.
I them tryed the factory reset, and it would come back, but them again, sometimes it wouldn’t turn on at all.
So, I though it could possibly be that the update via Bluetooth could be the cause of the problem and I did re-install the firmware, but this time using a Midi cable (Roland UM-One).
All though it seems to happen a lot less, it sill doesn’t turn on sometimes.
I have to mention that if it is turned on, it works with no problems.
Since I just got it, I’m wondering if this would be a hardware problem or software problem?
If it is hardware I will return it, but if not I’d like to keep it. (I got it used for a descent price)
I appreciate any help on this.
Thanks a lot!
March 18, 2016 at 4:15 pm #142911
If you did the factory reset and it still happens, it sounds like a hardware problem. It could also be a problem with the power supply – make sure you are using the right one.
March 18, 2016 at 4:44 pm #142913
HugoScaramal
Participantnickrose wrote:If you did the factory reset and it still happens, it sounds like a hardware problem. It could also be a problem with the power supply – make sure you are using the right one.
Yeap, I was using the one that came with it.
I also tried my TimeFactor power supply, but still got the same problem. I’ll probably return it to be safe.
Thanks a lot for such a quick reply.
Awesome customer service right there.
