H9 midi cc for pitch
Home › Forums › Products › Stompboxes › H9 midi cc for pitch
    • #111514
      monk
        I´ve got the pitch flex preset for whammy +2 oct. Which midi CC do you use to control the pitch?
        I tried the pitch bend function in my voodoo lab gcp board (I´m using the Boss FV500L as expression connected to the midi board) but it didn´t work properly. Is there a better CC value for this?
      • #125665
        gkellum
          All of the pitch flex presets are designed to work well with an expression pedal.  So, what you're going to want to do is assign a MIDI CC to control the expression pedal patch.  There may be one assigned already by default.  If I had a PitchFactor with me I'd check, but I don't.  But if you go into the system settings of your PitchFactor, you should see that in the MIDI settings section.
