H9 – Midi CC to control Set parameters?
Home Forums Products Stompboxes H9 – Midi CC to control Set parameters?
    • #113488
      harmamusic
      I’m posting this as a separate post as well as I’m looking for information how to set/change the Mix parameter of the active preset on an H9?
      Does the Mix correspond with Set Parameter 1? Default this is CC #22.
    • #143522
      gkellum
      Yes, the Mix corresponds to Parameter 1 and it defaults to MIDI CC 22.  If you look at the algorithm UI in H9 Control parameters 1 – 6 are the top row of parameters going from left to right and parameters 7 – 19 are the bottom row of parameters going from left to right.
    • #151659
      romax
      hi there
      is it possible to send midi to the randomize parameters function?
      either with the h9 buttons or a third party midi controller.
      many thanks
