H9 MIDI control
Home Forums Products Stompboxes H9 MIDI control
    • #114158
      promero85
      Hi, I would like to know if I can control 2 H9 via MIDI cable? I would like to load 2 effects (1 from each H9) at the same time. Thanks!
    • #146370
      You can if you set the first one to THRU.
      To load two effects with a single Program Change message, you will have to adjust the H9 MIDI maps to specify which effects you want to load. (See UM).
    • #146510
      promero85
      Just to be sure can I do this without using a MIDI controller? Just the two pedals?
      • #146518
        If [PGM.XMT] is on, when you load a program using the H9 footswitch it will send a MIDI Program Change which can be used to load a program on another H9.
        Use [XMT.MAP] to determine which program is loaded
        Make sure [XMT CH] and [RCV CH] are set to the same numbers (or OMNI).
        Set [OUTPUT] on the first unit to XMT.
