Home › Forums › Products › Stompboxes › H9 + midi + drum machine
I'm new to H9 and a complete novice to midi. Is it possible to send tempo from H9 to Alesis SR 18, so that if I set the tempo via tap tempo on the H9 the drum patterns will play in sync? Thanks.
Yes, you'll want to enable MIDI clock out on your H9; the setting is described on page 42 of the H9 manual:
http://www.eventide.com/~/media/Files/Audio%20Support/H9/Everyone/H9UserGuide18.ashx
