I’m trying to get the H9 to MIDI learn with the Disaster Area DMC 7D (same as 6D but with extra buttons). MIDI pedal is set to send note values. I’ve got H9 set to receive omni. DMC pedal out DIN to H9 MIDI in DIN. I’m in global mode on the H9. Go to [rcv.ctl], select [TUN], tap the right button for learn, send a note from the Disaster pedal, and nothing happens. Exit learn, and it hasn’t learned.
What am I doing wrong here? Page 35-7 of the manual doesn’t explain how to know if the pedal has learned, or whether it simply doesn’t receive MIDI notes, only CCs.
Thanks.
