Home › Forums › Products › Stompboxes › H9 Midi Messages
June 18, 2016 at 4:42 pm #113513
purpletiger
ParticipantI use 2 H9 units and use the Disaster Area Midi controller to Change presets on both units. The 1st units Input is connected to the Midi controller and its thru is connected to the the 2nd units input This works great. I have an EVH 5150 that can have its channels change via Midi CC messages. I am wondering if there is a change to send Midi CC messages on the 2nd unit so that when I change presets it will also change the amps channel. I know this ispossible onsome othere units but am not sure if I can do this on the H9 and how it would be set up.
June 18, 2016 at 4:56 pm #143605
It sounds like you want the H9 to send one or more CC messages when a program is loaded. This it does not do. (It's a guitar pedal).
My guess is that you need a more sophisticated MIDI controller that will send CC's as well as a Program Change.
June 18, 2016 at 8:34 pm #143609
purpletiger
Participantnickrose wrote:It sounds like you want the H9 to send one or more CC messages when a program is loaded. This it does not do. (It’s a guitar pedal).
My guess is that you need a more sophisticated MIDI controller that will send CC’s as well as a Program Change.
June 25, 2016 at 4:48 pm #143656
purpletiger
ParticipantThanks for response. I misspoke when I said that I wanted to send CC mesages. I want the 2nd H9 to send a Program Change message on a specific channel for changing the amps channel. I believe this is possible on H9 just not sure how to set it up.
June 25, 2016 at 7:51 pm #143658
This can be done with the latest (V5.4) software (on the same channel only). See elsewhere for details.
