H9 MIDI Question
Home Forums Products Stompboxes H9 MIDI Question
Viewing 5 reply threads
    • #116650
      apalazzolo
        I have read the H9 manual on MIDI (pages 26 and 46) and it does say that the H9 will automatically look to the usb port  when it is connected.
        I think the answer is “no” but my question is this:  If a usb host/controller is connected to a first H9 usb port to send midi output level messages to that first H9, can the DIN port of that first H9 still be used to send preset increment midi message from that first H9 to a second H9?
        I’m looking at simple (Midi Baby?) ways to use MIDI to control/change the output level of an H9 since there is no expression pedal control over the output fader.   I like the Idea of using the usb port but I think if I do that, I can no longer link two H9’s via DIN.
        All thoughts appreciated.  Thanks.
      • #158605
        bohan
          I think the answer is "no" but my question is this:  If a usb host/controller is connected to a first H9 usb port to send midi output level messages to that first H9, can the DIN port of that first H9 still be used to send preset increment midi message from that first H9 to a second H9?
          I'm looking at simple (Midi Baby?) ways to use MIDI to control/change the output level of an H9 since there is no expression pedal control over the output fader.   I like the Idea of using the usb port but I think if I do that, I can no longer link two H9's via DIN.
          The answer is NO. If USB port is connected, that will precedes DIN and H9 will ignore DIN.
          You can connect your MIDI controller to your first H9's DIN input, and connect your 1st H9's MIDI OUT to 2nd H9's MIDI IN. This should work for what you want.
        • #158607
          apalazzolo
            Thank you very much bohan!
          • #158625
            apalazzolo
              One other thought/question…
              When an H9 is connected to a MIDI host with a USB cable, does that H9 both send and receive MIDI commands through that one USB cable?
              I ask b/c it appears that the Disaster Area Midi Baby (3) has usb and DIN ports that are assignable for MIDI THRU.  So it seems I could achieve the goal described above as follows:
              Connect a MIDI Baby to a first H9 with a USB cable.  Set the MIDI Baby DIN port as MIDI THRU. And, connect the MIDI Baby to a second H9 using the DIN port.
              That way the MIDI Baby could send MIDI commands to both H9’s and MIDI commands from the first H9 would still make it to the second H9 (it would be irrelevant that one H9 is communicating through USB and the other is communication through DIN).
              Is that correct?
            • #158626
              joecozzi
                Be careful, MIDI Baby does not work with H9 using the USB port. I know this because I own a MIDI Baby 3. I confirmed with their support. Also, Disaster Area has a list of all compatible devices on their page. Our new dot9 series pedals, on the other hand, do work with USB-host controllers.
              • #158628
                apalazzolo
                  Now THAT is an important bit of information.  Thank you.
                • #158627
                  bohan
                    Yes. But the host should be something like a PC/Mac, but not a MIDI controller.
                    That way the MIDI Baby could send MIDI commands to both H9's and MIDI commands from the first H9 would still make it to the second H9 (it would be irrelevant that one H9 is communicating through USB and the other is communication through DIN). Is that correct?
                    No. Because once you connect USB port on your 1st H9, it disables it DIN input and output. Why don't you just connect MIDI BABY to your 1st H9 via DIN, and your 1st H9 to your 2nd H9 via DIN as well? Set your 1st H9's MIDI setting to thru, then you can use your MIDI BABY to control your 2 H9s.
                  • #158629
                    apalazzolo
                      bohan wrote:
                      No. Because once you connect USB port on your 1st H9, it disables it DIN input and output. Why don’t you just connect MIDI BABY to your 1st H9 via DIN, and your 1st H9 to your 2nd H9 via DIN as well? Set your 1st H9’s MIDI setting to thru, then you can use your MIDI BABY to control your 2 H9s.
                      Actually, if you read carefully, I am not proposing to use any DIN on the first H9.  If the USB is bidirectional the first H9 would transmit through the USB to the MIDI Baby (which would then pass data on to the second H9 – via DIN).   So it should be irrelevant that the first H9 DIN is disabled.
                      Regarding your question, space constraints and cabling considerations are more favorable for USB connections.  But that has become moot in light of Joe’s comment.
                      Thanks to you both.  I appreciate your guidance!
